engine swap 5.2L to 5.9L - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2012, 09:49 AM
I am swapping out the 5.2L for a 5.9L in a 1989 Dodge 1/2 ton 4-wheel drive short box, std. cab pickup. Typically the 5.2L is a internally ballanced motor, and the 5.9L is an externally ballanced motor. I'm keeping the same transmission, but am told I have to swap the torque converter & flex plate. I'm trying to find out if it's a lockup or non-lockup torque converter, and if it's a 11" or a 12" torque converter, with out dropping the transmission to check to see if the input shaft is smooth for 3/4" on the end. My nephue is still driving the truck, and the motor is at the machine shop getting rebuilt, waiting for a torque converter, so they can ballance the motor. Any help would be GREATLY appriciated. Thanks.
Old 08-26-2012, 10:40 AM
LATECH's Avatar
You should have a 518A trans. It will have an extra wire connection to the side of the trans close to where the neutral safety / backup switch is.
The connector will be behind the NSS/BUS a few inches and will have either 2 or 3 wires to it. If it has 2 wires , it does not lockup just overdrive, if it has 3 wires, it has overdrive and lockup. If there is no extra connector, it has no lockup or overdrive.
The balance issue can be solved by getting a weight kit for the torque converter and welding it on. The kit has a template to insure placement for welding.
My buddy did his last year and it worked well. Seems to me, ( I dont recall exactly) that he needed a flexplate from and older poly 318 . I dont recall the exact reason here. It might have been something with the crank stub pattern.
Also one of the 4 torque converter to flex plate holes was offset and was elongated to accomodate the torque converter pattern.
Maybe someone else remembers the flex plate issue a little better than I do, and will chime in.
Fact is stranger than Fiction
Old 08-26-2012, 10:57 AM
LATECH's Avatar
My bud ordered the weight kit from the Dodge dealer, believe it or not (MOPAR Performance parts) any good dodge parts guy will know.
Also B+M makes a plate that does the same thing. Part number 10236 flex plate. But its 65 bucks. The weight kit is cheaper.
Old 08-28-2012, 07:32 PM
Thanks guys! I had a couple local auto parts stores look everything up for me & they tell me the flex plates are the same part #'s for 5.2L & 5.9L. I'll find out soon if it's true or not, cuz I bought one from them. But I also called the local transmission place & they said 3 wires going to my nuetral saftey switch means lockup torque converter? That's what I ordered so we'll find out if that's true soon also. They also said most everything after 1978 will have the lockup t.c.? Thanks again!
Swap 250 engine and saginaw 3sp to 350 engine with t-350 or another manual? southerntidefan Transmission - Rearend 13 02-04-2011 10:17 PM
95 ford F-150 engine swap, Same Transmission fit new engine? F-150 Transmission - Rearend 5 10-07-2007 12:11 PM
86 K10 engine swap! swap tranny too? big_e111 Transmission - Rearend 3 08-03-2007 01:21 PM
Hello..need help deciding engine and or engine/tranny swap. suzukijohn Introduce Yourself 2 04-22-2007 09:35 PM
326 firebird engine swap with a 400 engine...is it possible?? greg67 Engine 7 11-08-2003 03:34 AM
