Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Swap: 5.7 LT1 into 1990 Caprice Classic
Old 06-11-2010, 10:55 AM
oldbogie oldbogie is offline
Originally Posted by capriceclassic1990
I'm looking at possibly swapping a 5.7L LT1 engine from a 1991 police package Caprice Classic into my 1990 Caprice Classic (original 5.0L fuel injected V8). I'm looking for any thoughts, hints, or criticism from anyone. Any and all input is appreciated, but please try to be helpful!
A 1991 cop motor would NOT be an LT1, at least not originally. The LT1 was not put into cop cars till 1994, even then most got the L99 which from the outside looks like an LT1 but is only 263 cubes which is a 305 bore with a 283/302 stroke.
Most 1991 Caprice cop cars came with a port injected 305 rated at 170 hp. A minority were equipped with the LO5 TBI injected 350 rated at 195 hp.
Rarely you might find one with the iron headed version of the L98 with TBI, but these are pretty unusual. The L98 engine is just an LO5 with different heads and injection, no big shakes down below. Either 350 may be a 2 or 4 bolt block, you can't tell unless the pan is off, nothing indicates which from the outside.
You need to look carefully before buying, check out the block casting numbers to determine whether you're looking at a 305 or a 350.
305's:
14088551, 14093627, 14094766
350's:
14079287, 14088548, 14093638, 14101148
Bogie
