Engine Swap: 5.7 LT1 into 1990 Caprice Classic - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2010, 06:28 PM
I'm looking at possibly swapping a 5.7L LT1 engine from a 1991 police package Caprice Classic into my 1990 Caprice Classic (original 5.0L fuel injected V8). I'm looking for any thoughts, hints, or criticism from anyone. Any and all input is appreciated, but please try to be helpful!
Old 06-09-2010, 07:56 PM
bigdog7373's Avatar
Of course it's fast
That sounds like a good idea to me. Just make sure you do anything you want to do to the motor before you drop it in the car; it'll be much easier that way.
Old 06-10-2010, 08:36 PM
This should be a bolt-in. The 91-96 B-body cars use the same frame as the 1977-1990 cars. Just get the frame mounts, harness, sensors, ECU, etc from the donor car.
Old 06-11-2010, 01:04 AM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
The only problem I see is that there is no such thing as a 1991 model car with an LT1. I certainly hope the engine was swapped and actually is an LT1.
Old 06-11-2010, 10:55 AM
A 1991 cop motor would NOT be an LT1, at least not originally. The LT1 was not put into cop cars till 1994, even then most got the L99 which from the outside looks like an LT1 but is only 263 cubes which is a 305 bore with a 283/302 stroke.
Most 1991 Caprice cop cars came with a port injected 305 rated at 170 hp. A minority were equipped with the LO5 TBI injected 350 rated at 195 hp.
Rarely you might find one with the iron headed version of the L98 with TBI, but these are pretty unusual. The L98 engine is just an LO5 with different heads and injection, no big shakes down below. Either 350 may be a 2 or 4 bolt block, you can't tell unless the pan is off, nothing indicates which from the outside.
You need to look carefully before buying, check out the block casting numbers to determine whether you're looking at a 305 or a 350.
305's:
14088551, 14093627, 14094766
350's:
14079287, 14088548, 14093638, 14101148
Bogie
Old 06-11-2010, 04:31 PM
hemi joe's Avatar
loves ex cop cars
easy way to check is vin number.also the 350 had 700r4 trans.
Old 06-16-2010, 01:23 PM
Also, you can check the RPO-Code sticker inside the trunk lid of that 91.
L03 = 305 TBI
L05 = 350 TBI
Old 07-12-2012, 02:05 PM
Not easy
I'm doing the swap right now I'll keep you posted
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Tranny and engine swap questions...."1990 caprice classic"th400 vs 67' muncie 4 speed 74chevyflat Engine 5 02-10-2007 09:28 PM
Engine Swap thundercatsteam Engine 4 02-10-2004 09:29 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 07:01 PM
