Engine Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2002, 07:02 PM
Post Engine Swap
I have a 1973 Chev. Camper Spl. It had a 350 ci.
It passed away : I bought a 1990 small block Chev. (supposed to be a 350). everything is bass - ackwards on it. Alternator on opposite side, different style a/c comp again on wrong side
plus no place for fuel pump. They took off the fuel inj. and put on manifold and Qjet. I don't want to go the computer route. Will my a/c system
work with the newer compressor? There seems to be no bolt holes in the right places to install all front of '73 engine components to the '90 engine. Has anyone else had this problem. What is the solution? Thanx for your help.
Old 12-18-2002, 07:45 PM
F-1Rodder's Avatar
Post
I think the answer is that you should return the motor and get the right one for your car/truck. You are going to throw money at this like crazy if you try to convert it over to the way it should be.
