Engine Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2005, 11:54 PM
Engine Swap
What would be the easist bigger engine to put into a trans am then a 305?
Old 07-12-2005, 12:15 AM
senor_limpio's Avatar
The Dude
What year TA?
Old 07-12-2005, 02:23 AM
USAF F-16 ELECTRICIAN
i just swapped out my 305 for a 350 and it was pretty simple. i was in a truck but i couldnt think it would be that much harder in a car.
Old 07-12-2005, 04:51 AM
Hippie's Avatar
Last journal entry: HEI comparison.
If it was originally a 305 then a 400 SBC would be the largest/easiest swap but they're getting hard to find. Next would be a 383 stroker. 383 crate motors are fairly plentiful. If you want a "previously owned" motor then a 350 is your best bet.
Old 07-12-2005, 08:59 AM
347mustang's Avatar
455 pontiac or olds
Old 07-12-2005, 08:43 PM
347mustang is right i forgot about that. the 455 olds and the 350 diesel had the same mounting pattern. so all you would need to do is put the 350 diesel engine mounts on the 455 (i know this is true for the 455 olds im not sre about the pontiac though). but after that much of a power increase put in a good th400 and a beefier rear end.
53 Packard Clipper Engine Swap? 53packard Engine 16 07-06-2010 04:32 PM
Engine swap for Blazer S10 ducktruck87 Engine 31 07-01-2010 08:44 PM
engine swap for S-10 Andrew7dg Engine 33 04-05-2010 07:08 PM
Engine Swap for Crown Vic edge Engine 12 11-03-2009 09:38 PM
engine swap question earthworm Engine 17 12-08-2003 01:53 PM
