Engine swap EFI 302 int a 65 f-100 that has 352 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2012, 04:17 PM
chuck M's Avatar
Hi I have a 65 f-100 with a 352ci and a 3 speed manual. I want to put in a EFI 302 with automatic trans. I have a donor truck with everything in it. Has anybody had any experience with this or know someone who has?
Old 10-23-2012, 03:31 PM
I think a better choice would be to rebuild the 352, as a 390. or even a 410.
Check the rear axle ratio on both trucks. If you do use the 302, you may want to consider a lower rear axle ratio.
But I understand wanting a modern fuel injected engine.
The Following User Says Thank You to DanielC For This Useful Post:
chuck M (10-27-2012)
Old 10-25-2012, 08:15 PM
chuck M's Avatar
The Truck is for my wife and i want it to be reliable and fuel friendly
1965 F 100 Ford, swap engine from 6 to V8 with same transmission? John Steiner Transmission - Rearend 8 05-23-2014 04:02 PM
first time project:78 camaro w/454 efi engine swap from a 2000 truck need pointers alex.trujillo48@yaho Introduce Yourself 2 09-28-2010 06:43 PM
1950 Plymouth convertible 302 EFI Swap jackndelphine Introduce Yourself 3 01-08-2007 06:28 AM
302 engine swap FAIRLANE DUDE Engine 2 03-31-2004 08:59 PM
engine swap (302) countryboy Engine 1 03-18-2003 03:19 AM
