Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine swap and modification!
Old 10-14-2002, 12:39 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is online now
Post
go the small block that big block is probably a 366 if it came from a dump truck, does it have dual thermostats on the intake and a harmonic ballancer with pulley grooves cast in it? if yes then pull the main caps off remove the rods and crank, sell all of them on e-bay and scrap the rest, only thing a 366 is good for
