engine swap need help fast - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2003, 09:05 PM
Post engine swap need help fast
i have a 1976 corvette with the 180 hp engine i was wondering if any 350 engine will bolt up to the th-350 and also if i would have to change motor mounts
Old 01-07-2003, 09:31 PM
Post
As far as I know all the Chev small blocks use the same mounts, at least all the later ones, we call any engine that goes on the TH-350 and Th-400 gearboxes Turbo pattern blocks : ) or the Chev pattern
Old 01-07-2003, 09:45 PM
Thumbs up
yes it will bolt up to the bell housing and the motor mounts you will want to take the flex plate
and starter off of your old engine and put them on the 350 to make shure that the flex plate will bolt to the torque converter, and use the starter
so you know the teath will match up. good luck
