Engine swap? TPI in a 1979 Camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2009, 05:23 AM
Hi folks,
a friend of mine has a big problem with his old Chevy 350 SB. A piston is broken. He looked here in germany for a swap engine and found a 350 TPI from a 1991 Camaro from another friend of mine.
So our questions are:
- do the TPI engine fit to the "old-style" Dynomax headers in the 2. Gen Camaro? Are the engine mounts the same? I think there was a change at 1986 or so????
Do we need to install a oxygen sensor in the exhaust to get such an engine running? Or is there a way to make the engine so "naked" to make it running with a less of electronic? It cames with all sensors an the ecu.
Yes it would be easier to swap with an identical engine, but the price is awesome and I know the car since a few years where it is from.
Old 08-28-2009, 05:42 AM
exhaust bolt pattern is the same
motor mount bolt pattern is the same. the mounts themselves might be the same too.
you need to run an oxygen sensor. not a big deal to add one to the headers
Old 08-28-2009, 05:52 AM
Thx va4cqd for you fast answer. We will think about that project.
Daniel
Old 08-28-2009, 06:28 AM
A new question about the electronic side of the swap.
Is there anybody who has the diagram for the ecu unit? I know how to convert the sensors to the old gauges, but I do not know how to connect the ecu stuff to the starting system and the rest.
And what about the fuel pump? I read a few things about the swaps, but often was a intank-fuel-pump used. The old camaro has the "manual" puel pump on the block. Can we use that in that way to at the TPI?
Old 08-28-2009, 08:09 PM
Last wiki edit: Hand cleaner Last photo:
Wiki Edits: 3
the mechanical fuel will not work, it doesn't build enough pressure for
a fuel injected motor.
for TPI, you will need a pump that can produce enough volume to run the motor at WOT and maintain at least 50 PSI minimum, 60~70 PSI would be better.
you can modify the fuel sending unit and use an in-tank pump or use an external in-line pump.
a fuel return line will need to be added to the car.
this may help with the swap your planning,
http://tpisuburban.edgesz28.com/suburban-home.htm
there may also be some useful info here,
http://www.eecis.udel.edu/%7Edavis/z28/
Engine Swap for Crown Vic edge Engine 12 11-03-2009 09:38 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Engine Swap - 64 Galaxie Billy Boy Engine 5 07-21-2005 02:49 PM
87 Trans Am Engine Swap Miserlou57 General Rodding Tech 3 02-01-2005 03:32 PM
95 Camaro engine swap torqjunki Introduce Yourself 1 12-18-2004 11:45 AM
