Engine Swap, What do I need to Look for? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2006, 06:33 PM
Last journal entry: Rear End Disassembly
My 340 went on me in my 71 plymouth gtx. I am looking to swap it out with a 440. I have found some good deals but am not sure on what years will work as far as mounting points. Can anyone help me on this, or is there a way to customize engine mounts so any year will work?
Old 03-27-2006, 06:45 PM
poncho62's Avatar
Wiki Edits: 5
Don't quote me on this, but I understand that the "K" member must be changed to go from a small block to a big block.
Old 03-30-2006, 07:41 PM
So then I can use any year motor?
Old 03-30-2006, 07:52 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
I think the main difference in 440's were the heads, comp, cam, ect...
I think the blocks are all the same other than that. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 03-30-2006, 08:18 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
sry Hemi, small blocks (LA) motors were different from B and RB series motors. LA were the 273-360 motors and the B were the 383 and 400 blocks. The RB (raised block) motors are the 426 and 440 mills. The 413 was also considered a raised block design as well as the early, late 50's 383 (the wedge motors).
K
« caddy | cam info »
53 Packard Clipper Engine Swap? 53packard Engine 16 07-06-2010 04:32 PM
Engine swap for Blazer S10 ducktruck87 Engine 31 07-01-2010 08:44 PM
engine swap for S-10 Andrew7dg Engine 33 04-05-2010 07:08 PM
Engine Swap for Crown Vic edge Engine 12 11-03-2009 09:38 PM
engine swap question earthworm Engine 17 12-08-2003 01:53 PM
