Thermostat installed right side up?
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
What application did you ask for when you got the Pump?
Didn't get a Reverse flow Pump by mistake did you? Or running a Standard flow direction Pump with Serpentine belt would give the same results. |
still not sure
just pulled pump looks ok flushed block and rad with hose water seems flow threw everything nice going to get a new pump and thermostat for it .. another question is i put centerbolt heads on a 72 block just drilled center intake holes to fit the heads the blocks r the same right?
| How Does A Thermostat Work? | cobalt327 | Hotrodding Basics | 16 | 03-16-2010 06:32 AM |
| Engine ran hot during break-in. What are my options? | V8 Super Beetle | Hotrodding Basics | 42 | 02-14-2010 06:52 PM |
| Identifying water pump configuration | ron2424 | Engine | 18 | 05-08-2008 12:29 PM |
| Ideal Engine Temp? How hot is TOO hott? | JAHamilton | Engine | 4 | 10-09-2005 03:58 PM |
| hot side, 350 tpi engine runs hot on one bank? | Ellisb | Engine | 16 | 10-27-2002 06:28 AM |
