Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Test Stand
Old 01-01-2012, 11:33 AM
gow589's Avatar
gow589 gow589 is offline
the Clever Turn Signal
Originally Posted by bob491
While not being a dyno I was able to do a few things, sort out a few things and learn a few things.
looks like a great Idea but it is only for one engine.
What is that thing behind the gauge panel that looks like someone mugged a computer.[/QUOTE]
If you can build this, modifying for other engines is simply a matter of cutting and welding mounts which is little trouble.
The circuit board is an experiment I am working with. I am reading a number of parameters, displaying it on the computer and data logging it. I am reading:
Temps: oil, water, intake air temp
EGT on each cyl with peak indicators
O2
Rpm,
Timing
Throttle position
Manifold pressure
The programing is done through visual basic. This is a sample screen:
