Engine Test Stand - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2009, 06:26 PM
freedom53's Avatar
Last journal entry: A Few Years Later...
Engine Test Stand
In the process of building an engine test stand. Trying to build it adjustable for different engines. Should the carb flange be level or is it critical? If it should be level as compared to having the engine itself level, I'll need to take additional design considerations; or am I just being anal?
Old 02-18-2009, 08:06 PM
low budget rodder's Avatar
Personally, I don't think it's critical. Cars go up hill and down hill, and they still have to run well... so engines (although mounted relatively stationary) change angle (relative to vertical) all the time. So... my vote - you're Anal!
Old 02-18-2009, 10:15 PM
freedom53's Avatar
Already I regret my choice of words!
Old 02-19-2009, 06:29 PM
Some where I have some pics of a test stand developed for various engines. If I can find them, I will post up to give you some ideas.
Trees
Old 02-19-2009, 06:58 PM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Typical engine front-to-rear inclinations are 3-6 degrees - side to side is normally level, but I've seen some that "pre-load" one side to offset the torque.
For a test stand I'd just make it so I could adjust the front-to-rear inclination or just set it at 3 degrees * which is probably easier!
Old 02-19-2009, 08:21 PM
powerrodsmike's Avatar
Wiki Edits: 161
We built this test stand, the trans mount is fixed, and the motor mounts are adjustable, in and out, up and down and fore and aft..you can't see it in the picture, but the 2x2 square tube uprights pivot in and out on a second lower bolt. The whole motormount adapter assembly slides on the 3x3 square tubing that the cart is made from for fore/aft adjustment.
If we run out of height adjustment on the motormounts, we shim up the trans.
We try to get the carb base level.
Later, mikey
ID:	36420   Click image for larger version
ID:	36421   Click image for larger version
ID:	36422   Click image for larger version
BE different....ACT normal.
Old 02-24-2009, 02:34 PM
*** Please post solutions ***
Wanna see some crazy test stands? Go to "youtube" one guy even starts his engine on a regular engine stand... surprised it didn't flip over.
Good Luck
-=Fred=-
Old 02-24-2009, 08:07 PM
life is a temporary assignment
Good Luck
-=Fred=-
When done right,There's nothing wrong with starting one on a engine stand.I have ran many like that.(even big block chevys).. You just can't get stupid when you give it some gas!!! (But not on a $25.00 Stand.)
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
engine stand JG700 Engine 20 05-20-2007 09:51 AM
Picís of awesome engine stand 406chevelle Hotrodders' Lounge 35 12-04-2006 07:17 AM
engine test stand mydixie Introduce Yourself 1 11-27-2004 08:02 PM
350 Chev Engine compression test Seon Engine 4 12-14-2002 09:20 PM
