What engine are you wiring?
Two cables, and two wires will crank an engine.
First cable, battery negative to engine block.
Second cable, battery positive to starter solenoid.
Third wire, starter solenoid to a switch.
Fourth wire, the switch back to the small terminal on the starter.
