Engine Test Stand - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-02-2012, 07:45 PM
KA67_72's Avatar
ShopAl,
Thanks. I have to admit to studying your stand at length before building mine.
Kevin
  #17 (permalink)
Old 01-02-2012, 07:48 PM
gow589's Avatar
the Clever Turn Signal
Most measurements are circuits which act like potentiometers. For instance the EGT is amplified through an AD595 chip which is quite standard and available.
Basically the chip is powered by the 5v on circuit and returns a 0-5v based on EGT temp. I read these values through an analog reader from Endurance R/C:
http://www.endurance-rc.com/analogreader.php
The analog reader is treated as a joystick input with 8 variables. Programing in Visual basic treats it as a human interface device. I run 2 at a time.
The timing was done through an OOPIC which no longer exist. A similar circuit is the Arduino which is a wealth of info on the web for. It used a Pak-VII chip for timing.
I am working on other circuits for the arduino which could do this independent of a computer and be independent gauges or indicators using LCD's.
Any of that make sense?
  #18 (permalink)
Old 01-02-2012, 08:27 PM
KA67_72's Avatar
I hadn't seen the Endurance R/C unit before. I looks similar in function to the DATAQ unit I have. Arduino reminded me, I also have a Atmel XMEGA microprocessor breakout board from Futurlec. http://www.futurlec.com/XMEGA_Controller.shtml It has to be programmed in C and I'm completely out of my depth. I bought AD8495ARMZ amps to do my EGT's and other temps because they're only $5 ea. I want 15 channels of temp and the DIPs were like $15 ea. I didn't realize how small 8msop was till they got here. I need to figure out some kind of break out for them. Eventually I want to have everything on one PCB but I'm in the early stages and still have a lot of programming to learn. The OPTO22 stuff is what I use to automate everything at work but it's very expensive and I don't have all the modules I want yet. Your GUI looks good. Our programmers at work use VB almost exclusively. I know enough to get in and troubleshoot if somethings not doing what I want but don't have a clue how to program from scratch.
Kevin
  #19 (permalink)
The mobile view is crap
Originally Posted by 03blackzz06
Just joined the HotRodders !, i in the process of building a engine test stand ( getting to old to build the motors and then drop them in the car to get them running ) thinking about a 3' wide x 5' long base to start ?, i have seen a few on evelbay but dont like the chinese junk!, anyone have any plans to build the good old USA way or have a site you could refer me to ?
Thanks alot for any imput
JR
Not sure where your located but when I built my stand I bought the plans on ebay. My uncle works at a fab shop and I had him cnc laser all of the parts for me. When he was looking through the plans and figuring out material cost he said out would be cheaper for me to buy the full stick of steel rather than by the foot. So I ended up with two stands. I completed one and is setup in my shop. The other one is in a pile on the floor waiting for a home. If your interested our anyone else I could figure out a price or a trade
  #20 (permalink)
Old 01-03-2012, 05:28 AM
gow589's Avatar
Kevin
Very cool Kev, I send you a pm. Gary
  #21 (permalink)
Old 01-03-2012, 05:43 AM
gow589's Avatar
Keven I was just looking at that board. It's amazing what you can get for $35!
  #22 (permalink)
Old 01-04-2012, 12:37 PM
electric brake
Is it possible to hook up the engine to a generator and turn back the meter a bit? A used electric motor in the 300 hp range can be found at locations where the corporations have used our tax dollars to ship the jobs to China. These motors can be turned into generators by the unemployed electricians who used to have jobs.
Clint
  #23 (permalink)
Old 01-04-2012, 12:42 PM
wow theres a blast from the past , looks like youre started building youre own shop now
i remembered a while back seeing the you tube clips of the quad turbo hot rod and you had youre own website but after a while they disapeared
so are you still working on the quad turbo setup for youre rod ?
  #24 (permalink)
Old 01-04-2012, 01:35 PM
KA67_72's Avatar
I just had a thought about the original topic of discussion. I bought a BBC crate motor once. It had mounts attaching it to a pallet. The previous owner started it on the pallet. What's to stop you from modifying a pallet or building a 4X4 or 2X6 frame to mount your motor to? You could even make a wooden radiator support.
I'm going to start a new Dyno thread. watahyahknow, I'll answer your questions over there.
Kevin
  #25 (permalink)
Old 01-04-2012, 03:13 PM
a while back i seen a picture of someone that used the undercarrage of a shoppingtrolly as a base , the front suported the trans and he welded some box iron on it for the engine support
  #26 (permalink)
Old 01-04-2012, 09:22 PM
This site
I don't have alot to say, I am just sitting back and trying to learn things from all you fine experienced folks on here.
Engine Breaking Stand Running Engine Test Stand sloughbum01 Garage - Tools 5 01-06-2012 10:55 AM
406 on engine test stand red406 Engine 9 05-13-2010 07:19 PM
Engine Test Stand freedom53 Garage - Tools 7 02-24-2009 07:07 PM
engine test stand gilby246 Hotrodders' Lounge 2 08-18-2006 07:05 PM
engine test stand mydixie Introduce Yourself 1 11-27-2004 07:02 PM
