Originally Posted by BlackAce
This is my first engine build up and want to break it in before installing it. This way if anything happens to break or fail. It's out of the car and easier to fix than having to pull the motor out again. That's why I don't want spend the money on buying one.
I was thinking of an engine cradle without the casters on it with an additional 12" mounted to the bottom created from angle iron. To support the motor and addtional clearance with headers? Then all I would need to do is create a control panel.
Check out post: "Betty Crocker meets Stewart Warner" for a control panel...russ
