Engine thermometer install - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2008, 06:41 PM
GMR GMR is offline
I'd like to place this temp gauge in my intake manifold.
http://www.jegs.com/p/JEGS/750805/10002/-1/10339
The manifold (Professional Products Crosswind) has threaded 1/2" NPT holes in front and back. I screwed in a brass 1/2 X 3/8 pipe bushing reducer in the hole and it sticks up 3/8". Do you think this will effect the gauge's accuracy?
Old 06-22-2008, 06:51 PM
DoubleVision's Avatar
Nope, it should work the same. However, I would run it to the cylinder head, this is where all the action is, combustion, heat, etc. So I would run it to the head for better accuracy. But this is just me.
Old 06-22-2008, 07:07 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Are you using it to check the gauge on the dash?
Look into Mr gasket rad. caps that have a gauge built into it, it will tell you it is HOT and to what degree.
Old 06-24-2008, 07:25 AM
GMR GMR is offline
Thankyou both.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
TPI engine install in 67 camaro Derby Dog Engine 0 01-25-2006 07:19 PM
