engine is tilted back - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2011, 03:50 PM
0pyders's Avatar
1986 firebird 350 chevy 700r4
whenever I removed the transmission the engine is now tilted back alot, is that normal or are the motor mounts worn out?
Old 01-01-2011, 04:08 PM
CJ_1080's Avatar
known to do dumb stuff!!
If the trans is still out and the engine is tilted back, that is normal. The rear trans mount on the tailshaft is what supports it and gives it its balance, when everything is bolted together.
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Pretty much normal .
Old 01-01-2011, 04:26 PM
0pyders's Avatar
Thank You For This Information.
Old 01-01-2011, 04:57 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
I usually prop the back of the motor up with a length of 4 x 4 to prevent destruction of the rubber in the motor mounts.
Old 01-01-2011, 06:50 PM
sqzbox's Avatar
My pipes are my music
Not good on the dist. and cap either.
Old 01-01-2011, 07:11 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
I think we all been there..
tilted trans 61bone Transmission - Rearend 7 09-03-2009 02:50 AM
Leaking coolant from back or top of engine? IMPORT TO MUSCLE Engine 5 02-02-2009 10:51 AM
Can an automatic trans operate tilted on it's side? Arrowhead Transmission - Rearend 31 11-30-2007 09:48 PM
Put back together engine but it runs like ****. 61ChevyTruck Engine 2 01-25-2005 10:53 AM
engine cuts out and back fires when hot digitalfrek Engine 1 07-14-2004 02:30 PM
