engine timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2002, 10:29 PM
slider in wa's Avatar
Slider in Wa.
Post engine timing
I run a 350 chev that came in my 57 chev when i bought it. I was told it had a 30 overbore and was a four bolt main. It has 202 f.i cast iron heads and a 30/30 duntov mech cam . when ever i get an engine that is unknown to me i have learned to do a few things. 1) i drop the pan and check #1 bearings. This is when i found out it was a 2 bolt main. I install a new oil pump.( i prefer high volume over psi)2) i pull the timing chain an put in a dbl roller. On this motor i installed roller rocker added a 7101 open plenum chamber eldbrock manifoild. ( which is really a top end manifoild and is wrong for my application.But it was layin their) I put a new 600 cfm eldbrock carb on. I rebuild an HEI dist. added the hooker headers. The engine has good compression at 170 lbs. My problem is that it rattles and pings going up hills.
I have used a light to time it. =no joy
i have used a vaccum guage to time it =no joy
I have timed it by ear=no joy
I added light weight springs to the dist=no joy
I installed a programable vaccumn advance unit= no joy. I even blocked the truck set the parking brake had my buddie pore on the throttle to see if i could get it to ping and rattle thinking i would set it that way=no joy. I don`t know but i might have pop up pistons in it, and this is a compression problem. The only time it runs well on hills is with hight test gas and octane booster. and even then it has a slight rattle. Now i know the manifold is wrong for the carb, but would it cause it to rattle? is it just not getting enough gas on the hills? So what do ya`ll think? Please advise!!!This is much more engine than i need or want in the truck. Oh yeah on the flats it screams!!!
slider in Wa.
Old 08-20-2002, 08:48 AM
Post
Try colder plugs they help by lowering the temp. in the combustion chamber. Learn how to read them at http://www.centuryperformance.com/spark.htm
You should have put stronger springs in the distributor so it wont advance so quick. Probably
should have your initial timing at about 6 degrees before TDC. Good luck.
[ August 20, 2002: Message edited by: hcheetwood ]
[ August 20, 2002: Message edited by: hcheetwood ]</p>
Old 08-20-2002, 10:51 AM
bullheimer's Avatar
NEVER use credit cards!
Post
hey slider bud, have you tried retardin it just a wee tad and see if that does anything? id don't know crap about advancing mechanisms of any kind of distributor-my uni-lite just does it's own thing. i'm thinking maybe your stuck using premium. but no way should you have to ad octane booster too unless you really do have pop-ups. (none of your buds called me back yet.)
Old 08-20-2002, 01:51 PM
Slider in Wa.
Post
Yes i have retared the timing step by step. With it not getting any better. I beleive that all timing should be by 33 to 35k and it is. as for the springs i used lighter dist springs think it would make it advance quicker. Maybe i should put the stock one back in and see if that helps!!! Good thing to look at . Thanks !
Slider
