Engine Timing Problems
First a little history - have a 350 LT1 (1970) engine that I have changed some parts on. Ran fine before, but could never get the engine to run right except at about 4 degrees BTDC. Several months ago, I purchased a new mechanical cam/lifters; purchased different heads (went from 76cc open chamber to 64 cc closed chamber).
Installed the cam and did the breakin with the old heads still installed and everything okay (still time at about 4 degrees). Installed the new heads and the rebuilder screwed up and installed valve guides that were too tight and the #4 intake slapped the piston, bent the pushrod and bent the valve (first time out). Removed the heads and had a local shop correct the problem.
Now for the issue. I can get the engine to fire and run, but it stumbles under acceleration until the rpm's get to about 3500 in any gear and engine smoothes out. Checked static timing and the balancer mark is nearly 5" away from the timing cover marker at idle with vacuum removed and plugged(engine starts fine and idles fine). Set #1 at TDC, valves closed and balancer lines up with -0- on timing tab. If I retard the dist., the timing marks move closer together, but the closer I get to -0- degrees, the engine will not idle without a lot of idle screw adjustment and if the carb is bumped, it backfires. If I set the timing by ear (good idle, etc.) I get the stumbling and hard to pull off issue (straight drive) and the crazy timing mark issue. New plugs, wires, dist. and coil and have tripple checked the wires for correct location (plugs to dist.)
Would changing to a lower cc head cause the timing to get way off or did something get screwed up when the valve slapped the piston? No damage to piston other than a fingerprint of the valve...forged pistons. I'm at a loss as to what is needed to fix this mess. Thanks.
