Engine too hot? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2005, 04:08 PM
Engine too hot?
I was looking through different threds, and found one on engine temp. After reading it, i realized that my engine might be running too hot. I'm guesing that below boiling is preferable. I have a 1972 chevy 355 (rebuild, was 350) and it ran around 230 for a few days until i tuned out the carb, which was too lean. Now it normally runs around 200 but it sometimes will creap up back to 220-230. This is with summertime temps of 70s and 80s. The only thing i can think of is that i might have crud in the coolent system.
Old 07-05-2005, 04:18 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
cooling
It's not a bad idea to flush your cooling system once a year.
Old 07-05-2005, 07:02 PM
how does one do that?
Old 07-05-2005, 07:43 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
You can take it to a repair shop and have it done for you, or you can go to the parts store and buy the heater hose adapters and install in line with you heater hoses and use you garden hose to forward and reverse flush the cooling system and the engine block. (you may want to remove your T-stat to do this).
The first will cost around $100.00 and the second around $10.00-$15.00. all depends on what you want to do. The first works the best because of the chemicals they use but it costs more.
Don't forget to look at the T-stat and coolant level. Also the amount of air being pulled through the radiator.
Does it get go up in temp when you are sitting in traffic or as you drive down the road?
Steve
Old 07-06-2005, 02:25 PM
there seems to be no pattern to when it heats up. i also don't stair at it very much, it's not boiling over so i'm not too worried. Could my guage be off?
Old 07-06-2005, 02:38 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Probably is. All stock guages are notorious for being wrong.
Old 07-08-2005, 02:00 PM
wrong by being too high or too low?
Old 07-08-2005, 02:01 PM
Both or either. Just plain inaccurate.
Old 07-08-2005, 02:05 PM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
Have you checked your cooling system? Thermostat, water pump, rad and hoses?
Old 07-08-2005, 03:47 PM
Alot of people over look a very important part of the cooling system, the radiator cap itself. The cap allows the system to build pressure, the pressure that the system builds raises the boiling point of the coolant. So with a 50/50 mix of water to antifreeze the boiling point of the coolant at 15 psi is around 272 degrees. So running at 200 should be no problem at all.
Oh and is there a fan shroud on the vehicle, this would help the fan pull the air across the radiator more efficiently
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
? about engine break-in. bowtieorbust Engine 9 10-09-2006 05:17 AM
not a hot rod question but i still need engine help mikeweyman Engine 13 10-23-2004 09:08 AM
Need Quick Help Plz - Engine Mounts Hot_Rod_Faith Engine 3 01-09-2004 09:52 PM
hot side, 350 tpi engine runs hot on one bank? Ellisb Engine 16 10-27-2002 06:28 AM
