engine tranny combo - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2006, 07:22 PM
engine tranny combo
Hello all, What would be a good engine/tranny/rear end combo for a 51 1/2 ton chevy truck. It still has the straight axle and closed drive. I plan on using it as a daily driver. I am considering a 350 crate engine, but am not sure of the transmission. I am not really sure of the differences.
Thanks
Old 01-10-2006, 07:38 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
The 350 crate engine is good due to its avaliability and cost. A bigger cubed engine will pull ya around easier though.
As far as Trannys go. Id use a well built Turbo 400. Takes a little power to run it, but its tuff. HG
Old 01-10-2006, 08:22 PM
Wiki Edits: 49
I would NEVER go with a 350 Chevy under any circumstances. There are just too many out there and I like to be different. But that's me. If you want a create 350 it's your truck so go for it.
Unless you're going racing there's no need for a TH-400. For an everyday driver a TH-350 is more than enough. If you're going to do a lot of driving on the interstate you might want to think about an overdrive trans like a 700R.
Good luck.
Old 01-22-2007, 06:45 AM
estrellam's Avatar
Don't be a fool wrap you tools
My brother has a 79 chevy malibu with a 350 that has some modifications and he went through 2 turbo 350's. Now he has a turbo 400 and it's really durable. I know your just going crate but I suggest getting the 400 for the long haul. As far as the gears go. I have a 60 ford 1/2 truck with 370 gears and a 351 engine. My suggestion is go with 370 gears. Good for street and has some stop and go in case some one is getting froggy.
Old 01-22-2007, 07:05 AM
mynuffinfutsitch's Avatar
dont get a crate motor
you can rebuild one for a fraction of the cost
what power range are u looking for?
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
tranny and rearend combo? dj72chevy Transmission - Rearend 4 07-01-2005 06:52 AM
Using tranny cooler to cool engine oil shagginwagonvic Engine 17 03-06-2005 09:55 PM
best tranny, rear end, converter combo? Siggy_Freud Transmission - Rearend 2 08-31-2004 07:44 PM
engine combo questions. Super Chevy Engine 7 06-27-2004 10:07 AM
