engine and tranny swap on a 62 lincoln continental - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2009, 05:23 PM
krazywayne's Avatar
Tattoos,bikes,and cars. yay!
After alot of research and help from these forums, I think i am gonna change my original plan of restoring the original engine
(430ci) and tranny (fordamatic) and do a complete change out. I was curious to know what skill level is required to swap to a 460-c6 combination on this car. I have heard this is around my skill level being not a rookie but by no means an expert. Any ideas from anyone who has done or knows someone who has done this is appreciated. My original plan was to rebuild but I have decided since money is a factor I will just get her running and slowly rebuild the original motor to put back in when i decide to completely redo the entire car. As I have too many projects going and would like to finish one before spring.
Old 01-28-2009, 05:46 PM
woodz428's Avatar
Troll Hunter
First, it's not a Fordomatic, it would fall into the cast iron cruiso/fmx category. The fordomatic was only a 2 speed,I believe..if I'm wrong I know Gary will set me straight . The simplest swap would be to get a bellhousing from an early Ford with an FE and swap in an FE. The Lincoln tranny was what they used( modified) in the the automatic Thunderbolts and should still have plenty of support in the parts area. There were also smallblock bellhousings that should bolt to it if you went that way. I think there will be much more work than needed to swap in a 460/C6 and the results may or may not be worth the effort. I'd look for some 430 parts and keep that engine. It is underrated and has a lot of potential...you might be surprised at some of the speed equipment still around. I think it was 1959 that the 430 Lincoln engine powered the Top Eliminator( pre Top Fuel) car in NHRA.
Old 01-28-2009, 09:29 PM
techinspector1's Avatar
Wiki Edits: 326
If we still had Sunoco 260 at the pump, I would agree with keeping the 430. But we don't, so I would lean toward a 460/C6 with flat-top pistons and D3VE heads.
I was planning on putting a 430/Toploader into my roadster, just to have something different. I bought the motor, scattershield and Toploader before researching the motor. The very large, crescent shaped combustion chambers are detonation-prone on today's unleaded fuels and speed parts may not be as readily available as one might think. 430's and 462's had wedge shaped combustion chambers formed between a flat head surface and an angle milled block deck (10 degrees off square with the bore axis), with the piston top determining the compression ratio and combustion chamber shape, similar to the Chevrolet 348 and 409 arrangement.
The back of the MEL block accepts an FE scattershield, so an FE trans should bolt up.
Old 01-28-2009, 10:37 PM
woodz428's Avatar
Troll Hunter
Very aware of how they form the combustion chamber, I bored many and am familiar with the jig required to do it( at least when we used boring bars that set on the top of the block), The 534( as well as the smaller variants) truck engine was similarly set up. I run many 60s era engines( do a lot of Ford muscle car work) that work fine on modern gas, although hardened exhaust seats are needed. I didn't figure the HP parts needed would be that radical since it was in a Lincoln and the money spent to swap a complete new drivetrain in would allow enough to get an intake and a cam.Depending on what he wants in the end really is the determining factor. If he wants a Hot Rod Lincoln, it shouldn't be hard to get it with what he has, you can shed a lot of weight from one of those boats...the doors probably weigh 500 lbs each( on a 4dr). If he wants a killer street machine...he might want to start with something lighter to begin with. If the Lincoln is in good shape there is a growing demand for the '61-'67 Lincolns and he could probably get enough for a more easily modified one.
Old 01-28-2009, 10:48 PM
krazywayne's Avatar
thanks guys for all the help..I am just starting this project and since the car is in pretty good shape as is. I am in a dilemna with what to do..I really dont know exactly what I want to do. Everyday I see something that would either help out performance or look cool and I guess I just need to set a plan in motion and stick to it but i do lve the idea of a HOTROD Lincoln but still believe the car is awesome as is.. so I think I will sleep on it for a few days anddecide soon. I am used to bikes and the thing I do to them but a car is a whole nuther monster. with the bike i just put it on and go. the car is a lil different that is why I am doing all the reasearch I can before I make a decision on what to do. If I could figure out how to put a photo up of the car I would.
Old 01-29-2009, 03:38 AM
aka Duke of URL
This was answered a few days ago-
-PREVIOUS MEL SWAP QUESTION-
I've only seen a few successful swaps. There are many constraints updating the slabside drivetrain.
-MORE 460 SWAP INFO-
Old 01-29-2009, 08:21 AM
woodz428's Avatar
Troll Hunter
Hi Gary , I thought the thread sounded familiar, I looked at the last one and saw that you had posted so didn't submit on it.....Are you noticing more "repeat" offenders....that ask the same thing,over and over?? I am.
Old 01-29-2009, 09:29 AM
aka Duke of URL
Only here... I keep asking the 'ol lady over and over for sex...
Old 01-29-2009, 12:14 PM
woodz428's Avatar
Troll Hunter
If that sweet looking Lincoln that you posted pics of is the car you are discussing, it would be a shame to do anything to it that would corrupt it. I'd put a nice set of wheels/meats and a set of magna flows or equivalent and enjoy.
If you want something to modify, contact me and we might be able to work something out. woodsy@gearheadcity.com
Old 01-29-2009, 01:04 PM
LOL, it weighs so much it will take a blower motor to make it scoot (that would look cool as a true "Hot Rod Lincoln"!)
my $.02
it is a very pretty "cruiser",,, just do minor mod's to the motor to help the street rpms TQ,, some lower gears and call the drivetrain done!!!
loose some (hidden) weight where you can if it's not a major pita project....
yeah, I'm in the "do not corrupt" camp on that specific car,,,build it as a "sleeper",,,modified stock air cleaner and all...
Old 01-29-2009, 03:09 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
You're looking at 2 1/2 tons of metal. That car is made to be a cruiser and not a speed demon. I'd rebuild it and keep it original, toss some wheels on it and enjoy it. The only thing else by building it up for a rod would be top end speed. And if that is it in the pic I seen, I'd love to have it. growing up my dad had '61,s, 2's and 3's. Heck of a boat then but nothing like them now
Old 01-29-2009, 03:20 PM
aka Duke of URL
...hmm...
You can do with it as you wish but what you are planning is going to affect the resale value of that vehicle.
A tasteful conversion can be done but that 430 can be built to deliver much better performance also.
Old 01-29-2009, 06:48 PM
krazywayne's Avatar
that is her..I'd like to think I stole it fromt he guy I bought it from. As said before I am not an expert and sorta new to the classic cars thing. I have always loved them and enjoyed working on them but this is a lil more than I am used to. I have started ordering some rebuild parts and contacted a few machine shops to feel them out. I have also decided to rebuild the original motor to keep the resale value up. I am probably going .30 over with the motor and a tranny rebuild too. I will keep you guys posted as my purchase and with input from you guys and alot of books on this particular car have turned into an obsession. I am loving this now. My passion was bikes and now I have fell in love with the good ole american steel of yesteryears. Thanks for the help guys!!
what are my options 62 lincoln Continental krazywayne Engine 4 01-27-2009 08:19 AM
Engine and tranny Swap in 78 Monte... BRSleeper2 Hotrodding Basics 6 07-08-2008 01:49 PM
86 K10 engine swap! swap tranny too? big_e111 Transmission - Rearend 3 08-03-2007 02:21 PM
Tranny and engine swap questions...."1990 caprice classic"th400 vs 67' muncie 4 speed 74chevyflat Engine 5 02-10-2007 10:28 PM
thoughts on Lincoln Mark VII engine swap dgkipp Engine 3 08-30-2003 09:52 AM
