Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine-trans-rear end combo
Old 03-18-2013, 03:01 PM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
Camaro has no e in it.
With that gear you do not want an over drive transmission. A TH350 would be as good as anything. If you went to about a 3.42 or 3.73 gear you could run an over drive transmission. The 700R4 can be built to work correctly without an ECM.
