engine-trans-rear end combo - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2013, 02:58 PM
I am building a 30s hot rod.I will be running a free breathing Chevy 327 ie: 650 cfm carb and a Edelbrock manifold with headers and ported and polished heads.I bought a Camero rear end I believe has gears around 2:56..what non-computer trans in automatic should I run for easy freeway driving? I dont plan on drag racing or burning off out of the hole..an answer would be appreciated.
Old 03-18-2013, 03:01 PM
big gear head's Avatar
High Performance Rear Ends
Camaro has no e in it.
With that gear you do not want an over drive transmission. A TH350 would be as good as anything. If you went to about a 3.42 or 3.73 gear you could run an over drive transmission. The 700R4 can be built to work correctly without an ECM.
Old 03-18-2013, 03:21 PM
Going off your recomendation would I get the same result going either way?
Old 03-18-2013, 03:46 PM
With the 3.42 or 3.73 and 700R4 the car would be quicker because of the extra gear. The TH350 and 2.56 would be just fine if you just want something to drive around and not worry about it being quick.
Old 03-18-2013, 03:50 PM
Sounds good to me..I just want a nice cruiser that gets good mileage..thanks for your info..
What engine/ trans combo ??? Severed TIES toy Engine 1 10-27-2010 09:38 AM
How to size engine, trans, rear end Mikemg General Rodding Tech 2 08-22-2007 08:16 PM
best tranny, rear end, converter combo? Siggy_Freud Transmission - Rearend 2 08-31-2004 07:44 PM
What engine/trans combo do I have?? thomasj392 Engine 4 12-12-2003 08:54 PM
c-4/flathead/rear end combo question dirtrules Transmission - Rearend 3 07-21-2003 06:32 PM
