Engine Trans swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2002, 04:32 AM
Post Engine Trans swap
I have a 1962 Chevy II Nova Wagon with a 350 3-sp manual trans. Planning on swapping in a 350 crate with th350 trans. Can you tell me of any major problems i may run into?? THANKS.
Old 06-06-2002, 06:05 PM
4 Jaw Chuck's Avatar
Post
Probaly have to change the driveshaft length due to different tailshaft lengths. Shift linkage will be all wrong, get an aftermarket floor shifter to solve that. You will need the TH350 speedo cable gear and end that goes into the trans, I suggest you get the entire cable from a TH350 equipped car as the speedometer end is the same for all vehicles. You might have to fabricate a trans mount or drill some new holes. Don't forget to get the right yoke for the tranny end also, you can adapt that to the existing driveshaft.
Anything I missed?
— Han Solo
Old 06-07-2002, 04:05 AM
Post
Thanks for the info 4 jaw...will keep these things in mind!.
