Engine/Trans swap 305/7TK - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2001, 06:24 PM
Post Engine/Trans swap 305/7TK
Hi Guys
I'm new to this and have a lot more questions than answers!
Bought a 49 Chevy truck I a=m restoring and am in the process of upgrading the drivr train and Chasis. I found a 87 full size Blazer with a 305 and 4WD auto, which I plan to slip under this 46.
Question I have is what has to be done to the tranny to get away from the computer?
There are two electrical connectors to the tranny. One is a 2 wire and goes into the 4WD case. I assume this is nothing more than the indicator to indicate in $wd or not?
The 2nd lead is a 4 prong, 3 wire lead into the driver's side of the tranny body. Do I need this and what is it's function.Sure would appreciate some pointers.
If you don't have answers but can steer me in another direction, I'd appreciate that too.
Thanks Guys!!! hcalteaux@hbci.com
Old 09-19-2001, 05:39 AM
Tom Tom is offline
Post
The plug in the transfer case is for the indicator you don't really need it the plug in the tranny is for the lockup ,in the early 80s chevy trucks had no computers but had lockup trannys.There is a switch on the firewall in these trucks with wiring for the trans that operates off intake vacume that makes the converter lockup like a electric vac modulator.got to be a million of them in the boneyards
Old 09-21-2001, 09:02 PM
Guy Guy is offline
Post
If that trans is the over drive model,the over drive is controled there
Old 09-25-2001, 10:38 AM
Phat's Avatar
Toy builder
Post
Hank Not to disapoint you but have you looked at a 49 with a blazer chassis under it? First the chassis is to short.Next the wheels hang out and does not look very good.Out of all the ones i have seen(and there are tons of them around),only one guy got it correct.He did a lot of body work and widened the front fenders. The rear is not bad at all,its just the front hangs out of the fenders pretty far.Just wanted you to know before you started.
Old 09-25-2001, 08:18 PM
Post
i do know that the plug on your tranny is what controls the the lock up of the comvertor and the you will need the plug of the wire ing harness there are two ways to make this work 1 painless wiring makes a kit and will control everything 2 you can make your own switch to control the converter lock up but i dont uderstand what the problem is you are using the frame motor and trans just go ahead and you the wiring harness-easiest
Old 10-01-2001, 10:08 PM
Post
I have had some luck with the late model front independant suspension by simply narrowing it , I had a driveling shop near me shorten the drive axels , this doesn't interfear with the cv joints . It compensates for the narrower frame of the 47 You cant go much shorter but its do able . I think wheel offset should be looked at too . We used the origional frame with alot of modification and it worked out well . As far as doing away with the computer , If you intend to drive it regular , leave the computer and upgrade it with a chip . The trans will work better , the engine will make more power and if you keep the wiring from the truck the engine came out of you can take it to a chevrolet dealer or garage and have it put on a machine when it screws up . We kept our computer and took it to a garage when it lost power . They looked up the year model we used to get our driveline from and told us it needed a mass airflow sensor , a quick fix . On thing I have found out about doing a custom is if Gm made it to work together , use it . It makes general repair and maintenance simple . There is nothing wrong with doing away with a computer , I hate them , but I love how the truck runs with one and the gas milage differance is enough to put up with a little aggravation of installiong a modified wiring harness ,, ,painless can help . My advice is dont be in a hurry and be willing to put together and pull apart till it all fits right . Get a factory wiring schematic on the doner truck so you will know which wires are computer and which ones are expendable . Besides , the electronic dash from some of these new trucks can be integrated into an early dash rather nicely . Have you considered putting ac on the truck , the computer will make that work nicely to , it did for us .
