Engine and Transmission Leveling - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2008, 12:34 PM
Hi, I am new this. I am building a 1929 Ford Hi-Boy with a Chevy 350 engine and 350 transmission. I have built the rolling chassis. I am now about to install the engine and transmission.
My question is on leveling. Do I make sure the Engine/transmission is level at the top of the carb, valve covers or according the the line of the spark plugs?
Thanks for any help.
Fiero86
Old 06-29-2008, 01:15 PM
Frisco's Avatar
Glad To Be Here
Fiero86
With the frame set a the ride height (wheels and tires mounted and installed and complete suspension installed); place the engine in the frame at the height you want the engine to be to give you the ground clearance below the oil pan you want. Then place a level on the carb base area of the intake manifold. Level the engine front to back as well as side to side. You can now measure, fabricate and install the engine mounts and the trans mount. The rear of the engine will be approximately 3 degrees down from the front. This is built into the intake manifold from the manufacturer.
Old 06-29-2008, 05:29 PM
Thanks for you help
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Help identify Mercury flathead engine / what clutch & transmission can i adapt Jean Phi Engine 1 11-08-2007 05:15 PM
Engine and transmission mounts cucumber1949 Hotrodding Basics 1 08-07-2005 08:15 PM
FWD Cadillac Engine RWD Transmission Question Dusty82 Engine 4 03-19-2005 03:39 PM
New Engine Built & Dyno'd babe_n_indy Engine 69 09-09-2004 07:26 PM
