Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine and transmission mounts
Old 08-07-2005, 07:40 PM
cucumber1949's Avatar
cucumber1949 cucumber1949 is offline
T-Bucket, Corvette, Mustang
Looking for insight from the experts on the forum.
At a cruise-in last night, I saw a 32 Ford street rod with a small block Chev motor and TH350 trans. I noticed that the engine was mounted using a front mount saddle, and after looking under the car, that the transmission was supported at the aft end of the tail shaft. The tail shaft was resting in a 'V' shaped cradle and was not directly bolted to the transmission - just resting in the cradle. This was an outstanding coupe all around.
I've heard that the early small block Chevys used front mounts but don't now when the side mounts came along.
I'm wondering what the pros and cons are for the front mount, and also if the transmission support I saw has an advantage over the traditional rubber block mount between to the crossmember and transmission.
