Engine and transmission mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2005, 07:40 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Looking for insight from the experts on the forum.
At a cruise-in last night, I saw a 32 Ford street rod with a small block Chev motor and TH350 trans. I noticed that the engine was mounted using a front mount saddle, and after looking under the car, that the transmission was supported at the aft end of the tail shaft. The tail shaft was resting in a 'V' shaped cradle and was not directly bolted to the transmission - just resting in the cradle. This was an outstanding coupe all around.
I've heard that the early small block Chevys used front mounts but don't now when the side mounts came along.
I'm wondering what the pros and cons are for the front mount, and also if the transmission support I saw has an advantage over the traditional rubber block mount between to the crossmember and transmission.
Old 08-07-2005, 08:15 PM
poncho62's Avatar
Wiki Edits: 5
Can't see that the tranny was just sitting in a cradle. Upon hard driving the rear of the tranny would jump right out of there and hit the floor.
Also, having the mounts that far apart puts a lot of strain on the bell housing bolts....not recommended. Side mounts started in the cars in 1958.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Hot Rod w/ a Japanese engine and transmission and a passanger car frame alex_0227 Hotrodding Basics 27 05-28-2005 02:07 AM
FWD Cadillac Engine RWD Transmission Question Dusty82 Engine 4 03-19-2005 03:39 PM
New Engine Built & Dyno'd babe_n_indy Engine 69 09-09-2004 07:26 PM
Engine & transmission -HELP! 59vette Engine 5 04-26-2004 03:31 PM
