Engine/transmission paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2007, 03:36 PM
Does anyone have any experience with custom paint on engines and transmissions? I need to paint some drivetrain parts and want to go beyond rattle can Hi Temp paint. I often see high end show cars with matching paint to the exterior on engines but wonder about it's longeviety. I have used 2 part polyurethane Awlgrip paint in the past over epoxy primer on boat engines with some success but wonder what y'all are using these days that is durable and really pops out. Base coat/ clearcoat an option? what else?
Old 05-21-2007, 04:06 PM
DV8's Avatar
DV8 DV8 is offline
Sloe Lurner
Last journal entry: front boxing plates
Powdercaot
Powdercoating. I have not done it myself yet. This is just what I've seen latley
Old 05-21-2007, 04:31 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
While I don't know what the latest paint products are I do know that its the prep work that makes it POP.
IMHO
My latest spray bomb stuff
R
ID:	21344   Click image for larger version
"SlowRide66"
"Illegitimis non carborundum"
Old 05-21-2007, 06:53 PM
Chris Ryan
I just clean real well. Shoot some epoxy on it, then spray with base clear.
http://a480.ac-images.myspacecdn.com...c9b5e55497.jpg
Old 05-21-2007, 07:15 PM
I shot my engine with PPG 2 part single stage (no clear) and so far it is holding out well. I wanted to keep the coating thickness down, so no primer or clear, just clean really well before painting. I cleaned the engine really well and used spray cleaner (brake clean) to get the oil out of the castings.
Old 05-22-2007, 10:28 AM
Rob Keller's Avatar
Wiki Edits: 38
That Purple stuff is kick arse for de greasing!!
R
"SlowRide66"
Old 05-22-2007, 10:54 AM
302 Z28's Avatar
Base coat/clear coat is the way to go for looks and long term durability. Would not want to powder coat an entire engine .
Vince
Old 05-22-2007, 12:27 PM
Last journal entry: Body work
I had a 68 amx years ago and had a local paint store mix a synthetic enamel in the original amc engine color and was amazed as the years went be how durable that paint was. Years later I decided to build that same motor up and even after a chemical vatting at the machine shop there was still paint on the block. I believe it was martin senior paint. It held up great, even at the exhaust port on the heads where temps are high, no dis-color.
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 02:20 PM
"Basics of Basics" Color Matching-Alternates MARTINSR Body - Exterior 2 02-03-2007 06:33 PM
what color to paint? jum Body - Exterior 14 07-30-2006 12:29 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
