Engine / Transmission Spacer Plate Problem
Hello!
Ive got a Mustang with a 351W and now C6, it had a C4. I did the change myself, all went pretty good for my first time. It was actually easier than I thought... However I now have run into a small problem. Upon trying to install the starter I notice that the spacer plate, between the engine and transmission, is in the way of the mounting holes for the starter. There is also no way the starter will fit, the plate is too much towards the inside. I suspect its because the C6 transmission simply had the starter mount area exteneded out farther. I do not want to remove the transmission from the back of the engine again and replace the plate if its not really needed. Would it do any harm to just cut out that section, to expose the bolt holes and make room for the starter? If anything I may need a spacer of some kind as the starter would sit a little deeper into the trans. If someone could tell me how to go about this or confirm my idea to fix the problem, Thank you. |
I don't see why you couldn't trim the spacer as long as you don't take away any structural qualities or any SFI rating is involved. Virtually all SFI certified parts lose the cert if altered.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
I wish I could trim it but its too much in the way, its got to be cut completely out... Would it put too much stress on the mounting area? I know the starter kind of rest on the plate too....
Come on, any input here?
Yes just the plate is in the way, I had the starter bolted to the trans before it went in with the flywheel and all, it was a perfect fit. Just forgot to check the plate.... After looking at it more I may be able to get away with alot of trimming, but atleast some structure will be left, and then drill holes in the plate to expose the mounting holes on the trans. Thanks
After some thought ive decided it would be best to get a new plate but what im looking at says it will work with C4 and 6. How is that possible? The old does not work on both. Here is what im looking at.
http://macsautoparts.com/product.asp...cd2=1291755988 |
Ok guys. Ive found out the problem im sure. So here goes for anyone who comes across needing the same help.
The C4 used two different spacer plates between 157 and 164, C6 used 164. If your trying to swap spacer plates it will not work if the C4 plate you have is for the smaller 10-1/2 bolt pattern torque converters and 157 tooth flywheels setup. You need a spacer plate from the larger 11 - 7/16 bolt pattern torque converter and 164 tooth flywheel, which will then work on a C6. I had the smaller 157 setup which is why it will not fit perfect. Atleast this is what ive gathered from searching all over the place... |
| Spacer plate question& Finish humor | Scandinavian | Engine | 7 | 08-12-2011 09:20 AM |
| carb spacer plate | vetteman | Engine | 6 | 07-27-2008 11:57 AM |
| Welding Transmission Plate | 70chevellene | Body - Exterior | 2 | 12-06-2004 04:37 PM |
| spacer plate what does it do? | CurtisL | Engine | 5 | 11-02-2003 03:12 PM |
| Th350 going to break, how to make spacer plate holes smaller? | Jason | Transmission - Rearend | 7 | 06-30-2003 10:29 PM |
