Engine and transmission startup help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2004, 03:38 PM
59vette's Avatar
Question Engine and transmission startup help?
Having installed new cam and bearing in my engine, along with a new converter and filter in my TH400 how exactly should I start this up?
Cam break in call for ~2000rpm when fired, but what about the transmission then.
Will it be OK?
Should I just leave it in park for the break-in period, and only go through the gears after the break-in, when rpms are lovered a bit?
any help appreciated
Thanks
Old 04-18-2004, 05:44 PM
71 c-10's Avatar
just a kid and his truck
hehe i was gona say you shoulda done them separately, but i figured i woulda done the same thing, i would call cam or converter company tomorrow, unless some one else out there can help ya out.
Old 04-18-2004, 06:00 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
No problem at all. Just make sure you have plenty of oil in the transmission and watch it for leaks. If you have to stop and add oil or fix a leak, just pick back up where you left off untill you get at least 20 minutes run time above 2k RPM.
Chris
Old 04-18-2004, 06:33 PM
71 c-10's Avatar
awsome, i'll rember that when i end up doing the same thing some time.
