engine and transmission swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2011, 11:01 AM
hi, i am new to this forum and like to say hello to everyone, i joined because anytime there is a problem out there this forum usually has a good answer.my question is this: i am swapping the motor and trans out of my 1989 chevy suburban it has a 5.7 tbi and a 700r4 trans with a tv cable and mechanical speedo. i am going to put it in my 1993 chevy 1500 pick-up which has a 4.3 tbi non vortec engine with a 4l60e trans with a electronic speedo.I know by this forum it is not a problem to do the motor as the harness is the same,my problem lies with the tranny,i just found out about the closed loop information,and i'm a little worried. but than i read about swapping the prom from a stick shift or would i have to get the whole ecm. any problems or solutions would be greatly appreciated because i plan on doing this on my vacation in a week.
1991 chevy 4x4, 350 engine, transmission swap? blurrydan Transmission - Rearend 1 01-11-2010 06:52 AM
Transmission swap dmangrum Transmission - Rearend 1 10-27-2009 12:43 PM
95 ford F-150 engine swap, Same Transmission fit new engine? F-150 Transmission - Rearend 5 10-07-2007 01:11 PM
307 to 305 engine/ transmission swap pjd Engine 6 08-19-2005 10:47 PM
t5 transmission swap traub83 Transmission - Rearend 8 05-18-2004 03:14 PM
