Engine tries to start when battery connected - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2005, 12:28 AM
V8 Datsun's Avatar
New Member
Last journal entry: Paint and engine
I have recently completed an engine transplant in a 1976 Datsun 280Z. I replaced the inline six cylinder with a Chevy 350. Tonight when I went to hook up the battery for the first time the engine started to turn over. The ignition switch was off and the car was in park.
I did not let it continue and stopped it by disconnecting the negative cable from the battery. I have a Summit mini starter on my engine instead of the factory starter and it did not come with any instructions on wiring.
I have the positive cable and the large wire that went to the Z's starter hooked to the large bolt on the Summit starter. I also have a smaller wire that went to the Z's starter hooked to the smaller allen screw connection on the Summit starter.
Can anyone tell me where I am going wrong?
Old 08-29-2005, 04:56 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
The starter should have places for two small wires. One should be marked S This is where the wire from the ignition switch goes. The other terminal should be marked R This is for the wire to the ignition resistor if you are using one.
Old 08-29-2005, 07:05 AM
rrmccabe's Avatar
GM Muscle
Sounds like the problem is with the old Zs starter wire. It might not be what you think it is.
Disconnect the small wire from the starter and hook the battery back up. At this point the engine should not turn over. Take a voltmeter and verify that small wire has 12 volts to it. IT SHOULDNT but appears it does in your case.
The wire that connects to the starter solenoid terminal should only have power when you turn the ignition switch to start position. You need to trace this back and find out why its hot all the time or if its even the right wire.
Rich
Old 08-29-2005, 07:18 AM
V8 Datsun's Avatar
New Member
The Summit starter did not have any of these markings. My older boat anchor GM starter did but it is a little too large to work in my cramped engine bay.
Which Z wire are you refferring to? The one I have hooked to the large terminal or the small wire going to the allen screw terminal?
Old 08-29-2005, 07:31 AM
T-bucket23's Avatar
Wiki Edits: 26
Starting
Check to see that the wires are not touching on the starter. Sometimes when tightening the wires they can move around enough to hit each other. Also if you disconnect the small wire does the problem go away. If not the starter is bad, solenoid probably internally shorted. If the issue does go away after removing the small wire. My guess is you have the wrong wire. Get a diagram and check wire colors for the Z. sounds like you may have gotten a couple wires crossed up somewhere.
Good luck
Old 08-29-2005, 07:48 AM
rrmccabe's Avatar
GM Muscle
I am talking about the one attached to the small allen terminal. Thats your solenoid wire and is what inititates the starter.
Remove it and make sure the cranking stops. It should. Check that wire with a voltmeter. It should not be hot with 12 volts but it sounds like it is.
Rich
V8 Datsun's Avatar
New Member
Woooohoooooo!
Man was that simple! Just as the above post suggested I had my wires touching. It was dark last night when I was finishing up and my main concern was getting the battery and starter wires away from my exhaust and in doing so I must have brought them together.
The beast fired right up when fuel reached the carb. Oh man I cannot wait to get her on the road.
By the way I was away checking on that very problem when I came back to my computer I saw where someone had suggested the wires may be touching. Thanks guys.
I will have to update my Project journal with some nice new pics.
Old 08-29-2005, 08:49 AM
rrmccabe's Avatar
GM Muscle
Good deal.
Sometimes its the simplest thing !
Old 08-30-2005, 07:11 AM
T-bucket23's Avatar
Wiki Edits: 26
Starter
glad it worked out for you. It is easy sometimes to overlook the simple things and get in way to deep
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
350 sbc upgrade... Engine will not start FenderGitars Engine 10 10-08-2010 03:26 PM
Rebuilt engine won't start bjam2 Engine 5 10-09-2003 05:01 PM
Want That Engine To Start john coleman II Engine 5 07-16-2003 07:41 PM
how to start a sitting engine pete379 Engine 9 07-08-2003 01:07 PM
