engine trouble , runs rough - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2006, 05:26 PM
Hi I have a 69 z28 camaro, but the engine is a later model 350. The engine ran fine before with not smoking or rough idle... but had a large cam. I put in a smaller one to help with gas mileage. The timing is right, but the engine runs rough and will backfire through the carb at about 1/2 to full throttle. The vacuum gauge is fluctuating rapidly from 12 to 16 and smoothes out to 18 when the engine revs up to about 2500 rpms. The plugs are clean and the wires are all good. Could this be a vacuum leak or intake leak. and if so how can i tell.
Old 09-04-2006, 04:04 AM
Known traffic menace
running rough
To check to see if your intake is leaking, get a can of carb cleaner and spray it around the intake flanges to see if it is leaking, if it is you will notice a change in the idle. As far as backfiring, double check your firing order if your timing is right. Hope this helps,, Perry.
Old 09-04-2006, 04:36 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Check your Valve lash..Sounds like you have one or more too tight.
Happy and Safe Labor Day!
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
95 Dakota 2.5L 4cyl. Runs Rough Help! TT66' Engine 7 06-13-2006 04:05 PM
Why a Cold Engine Runs Poorly leejoy Engine 10 04-10-2006 12:29 PM
Engine Runs After Key is off? my350camaro84 Electrical 11 07-24-2005 10:36 AM
olds 455: engine idles rough when started cold. 98rocket Engine 5 05-09-2003 06:01 PM
hot side, 350 tpi engine runs hot on one bank? Ellisb Engine 16 10-27-2002 07:28 AM
