engine turned inserts - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2003, 07:40 PM
Post engine turned inserts
i am looking for a company who sells engine turned silver foil striping like what jc whitney sold years ago. i would like to use it on my dash like the later 70's trans ams had. any help would be appriciated. namdlo@fidnet.com
Old 04-18-2003, 12:45 PM
Dragon J's Avatar
Last journal entry: Harley/Fire
Post
I know the stuff namedlo- but don't know any dealers- it is self-adhesive decorative vinyl and some of the metal looks are really cool- a guy here in town applies them so I'll ask whenever I see him- I just think he gets it at a hobby store in one of the bigger cities. Try a search under vinyl graphics maybe- good luck!
Old 04-18-2003, 01:23 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Post
Or, it could take a whole lot of searching, but check all the "Arts & Crafts" listings on the web and in your Yellow Pages.
Alan Horvath
http://AlanHorvath.com/
Old 04-18-2003, 01:28 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Why not just make it? T/A's dashes were aluminum sheets, not foil. All you would need is some aluminum sheeting a drill press and some time on your hands and you have yourself a dash. The turning mandrels are only a few bucks. I think even Eastwood sells them.
HK
Old 04-20-2003, 06:09 AM
BOBCRMAN@aol.com's Avatar
Post
Turning mandrels? and all these years i've been using a drill press and the erasure end of a large pencil with some valve grinding compound!!
Old 04-20-2003, 06:44 AM
38 special's Avatar
Be the MIRACLE!
Last journal entry: Running boards (part DUEX)
Post
You can use wood dowel rods and stuff called liquid sand paper in a drill prees too.
Old 04-20-2003, 09:37 PM
New Member
Post
Haneline may already have the pattern. If not make one and send it to them. They will make a beautiful stainless steel engine turned panel for around $100.www.haneline.com/
Old 04-16-2004, 12:40 PM
engine turned foil
Any luck finding an engined turned foil -- Duesenberg pattern? Looking for same to decorate a book cover.
Old 04-16-2004, 06:49 PM
FASTFORD's Avatar
try this company, they sell sheets of engine turned aluminum or stainless steel with different sized patterns to chose from.
www.fpmmetals.com
they also sell a few pre-shaped panels. hope this helps.
