Hotrodders.com Streetbeasts lawsuit Beat the Beast -- defend free speech!
Streetbeasts lawsuit fundraiser
Goal: $10,000. Amount raised: $3,440.
Get the latest news on the lawsuit.
Thanks donors!
Click here to donate, or see more details about donating.
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 02-19-2005, 07:07 PM
TwistedDragon's Avatar
TwistedDragon TwistedDragon is offline
Engine turning aluminum?
Can anyone tell me how to do this? I've seen it done with a bench model drill, but is it possible to do it with a hand drill? I love the look of it, I just dunno how to go about doing it. Many thanks if anyone can help me
Old 02-19-2005, 07:31 PM
crazy larry's Avatar
crazy larry crazy larry is offline
Streetbeasts lawsuit donor
you can do it with a hand drill, but the likely hood of slippage is huge.....
I've never seen anything but an eraser like roll used for it... I know eastwood carries them, among others i'm sure.
as far as how to do it, pick a corner, hit it with the burnishing roll til desired result appears. keep an even spacing to your pattern, and go to town. as much fun as porting your own heads i can guarantee....
Old 02-19-2005, 09:42 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
I've done it with those 3M abrasive pads held in a milling machine drill chuck with a little varsol as a lubricant, you will need to fix the part in place (so it doesn't move) and be able to index it so it looks right. Use the lowest RPM you can and light hand pressure or else the polish marks turn out dull...especially on aluminum.
Outlawed tunes from outlawed pipes
Old 02-20-2005, 05:37 AM
BRENT in 10-uh-C's Avatar
BRENT in 10-uh-C BRENT in 10-uh-C is offline
Rod & Resto Shop Owner
There are many ways to do it. Since this trick was performed by backyard builders from the 20s & 30s as they copied luxury car companies using aero engines and etc., they did it without the aid of a mill.
To do it where it looks the best, find you anything that you can chuck into a drill press. This can be anything from a wooden dowel, to a cut-down broomstick ...all the way to a hard cotton roll.
Whatever size you decide on, measure the burnishing end's diameter. What ever that number is ...divide it by 1/2. (i.e.: 1" = 1/2"). Lay out a "grid" using a dental pick to scribe into the aluminum on a 1/2" (if you are using a 1" burnisher) grid. All you are wanting to do is score the aluminum enough to be able to reference off of.
Next make a fence for your drill press. What I have seen is a piece of plywood with a 2/2 glued to one end. If you will layout some indexing lines on the fence that will help speed up the process too. Clamp the board/fence onto your drill press with the burnisher centered over the top of your first intersecting line at the corner. It really doesn't matter at which corner you start at but you will end up on the opposite side's corner furtherest away from where you are starting.
When you burnish, remember you are overlapping by about 50% in each direction so that all that you are really doing is 90 degrees of the "turn". (i.e.: like from 12:00 to 3:00 on a clock). What I think works best is to use valve grinding compound. It is available at most parts supply stores and usually comes in two grits. Use the fine grit for aluminum and the coarse grit on stainless.
Oh, BTW, make sure your panel is polished prior to beginning and do your burnishing prior to drilling holes if you want it to look it's best. Good Luck!!
Old 02-20-2005, 06:36 AM
Maybe its time to get my old coal mine machine shop mini drill press out of storage and go out cleaning it up. I suppose they're a good thing to have right? Now I just need someone to walk me through that too
Old 02-20-2005, 08:00 AM
pro70z28's Avatar
pro70z28 pro70z28 is offline
I have a CNC router that would work great for this. Just map out the grid on the puter' screen and let the router turn the design. I kinda' like the look of plain polished aluminum tho.
Old 02-20-2005, 05:40 PM
Well this is only to accent a few parts on it, I don't want it everywhere. Except when it'll come to the valve covers, I want alot there, it'll look niiice, with that and some wrinkle finish on it, I'll have a nice looking engine, even if it is in a Taurus
Edit: And I mean on another part of the valve cover, not over it, I'm not dumb
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Engine turning aluminum?"
crate chevy 302??? Vancouver Grand Prix Engine 89 02-06-2010 07:28 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 47 05-01-2009 11:14 AM
Aluminum Austin Healey engine?? chrome_ashes Hotrodders' Lounge 7 08-31-2007 08:19 AM
aluminum chevy engine blocks classic_chevy_guy Engine 8 10-02-2003 03:46 PM
ENGINE BALANCING NAIRB Engine 10 12-28-2002 06:09 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2010. All Rights Reserved.
