Engine Valve Couver with baffle - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2003, 09:30 AM
New Member
I have chev 350 engine with 202 heads roller rockers and a stud girdle.The valve couvers that are on the engine are a tall valve couver but have no baffle .With out the baffle i have some oil that comes out of the breather and makes a mess.I also do not have a pcv valve in the system so i guess iam not venting my crank very good.I do not whant to change the roller rockers or stud girdle what iam looking for is a set of tall valve couver chrome with baffles that will clear the stud girdle and let me put a pcv valve in the system.I could use some heip from you guys.The car is a 1978 custom vette.350 400hp.
Old 07-09-2003, 10:30 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Is there a place to punch out and put in grommets? You could also put a cross over tube beween the covers to vent the engine and keep oil from seeping through. You can build baffles with sheet metal and epoxy or cold weld to suit.
Old 07-09-2003, 11:07 AM
superrodder's Avatar
One problem some aftermarket valve covers have is the hole for the breather is directly over a rocker arm and the rocker slats oil up directly at the breather,causing a mess.
You can make a thin tin shield that will miss the stud girdles and cover the breather hole on the inside of the cover and pop rivet it in place.I'd make the baffle cover most of the underside of the valve cover so the oil has a long way to go to get out.one in each valvecover and put the pcv valve in one and a breather in the other and your good to go.
been there,done that
Old 07-09-2003, 11:24 AM
Bumpstick's Avatar
Hammer and a torch
You can also just get the push in type breather that has a 1/2" hose connection and run high temp hose down to the headers and install the one way valves that dump to the exhaust... (do this on both sides...) No need for a PCV valve then... Its an oil scavange system for drag cars and works great...
