engine vin codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2010, 07:53 PM
engine vin codes
hello all,,,, im trying to figure out exactly what year engine i have , i have posted before but cant seem to find everything on it ,,,,,,,numbers as follows
back off the block 14010207 beside it is CFD
passenger front engine pad is VO111FSM just below this is CE4135849,
from what i have found so far is i believ it to be a 80-85 350 possible 4 bolt main, but i would like to find out the rest of the vin numbers mean, any help here would be great, i cant seem to find anything on engine passenger pad numbers, what the hell do they mean,,,,,thanks again everyone much apprecaited!!
Old 09-24-2010, 07:58 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Go here for a readout: http://www.chevy-camaro.com/chevy-ca...es.asp?group=2
Old 09-24-2010, 08:31 PM
DoubleVision's Avatar
Look on the bell housing flange. On it will be the blocks date code. It will look like this example:
B 5 2
B is the month, 2nd month: Feb.
5 is the date, the 5th
2 is the year. 1972. (this will vary depending on the years the block was casted by it`s casting number)
It can also look like this example:
B 5 72 depending.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Engine casting numbers and vin numbers drfo Engine 5 06-18-2010 05:15 PM
Anyone decode a engine VIN no.? rp23g7 Engine 8 06-05-2010 03:06 PM
Is This Engine A 428 Or..... Have Codes Off Of Engine jordan2011 Engine 2 03-12-2007 10:07 PM
