Engine and Vin # Decode Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2010, 08:10 AM
Last journal entry: More pics
I need a little help in deciphering this cars #s.
Vin # 164679C043566
Engine block # 3932388
Head #'s 3932441
Engine Suffix Code #T0904HV
After hours of research the only thing I can tell is that this is a 1969 Impala Convertible V8 with either a 302, 327, or 350.
The Year One website says that since the engine doesnt have a VIN # next to the Suffix #, the engine was not installed on a chassis on an assembly line.
The HV suffix said the block was for a 1965 327/350hp Vette?
Chevrolet Engine Suffix Codes
This is the info I have on the heads.
3932441 1969-70 350 intake 1.94 stroke1.5 cc76.26
And to throw me off even more, I have 327 side markers!!!
All help is greatly appreciated in telling me what I have sitting in my engine bay.
Old 10-12-2010, 04:07 PM
Vin # 164679C043566
Head #'s 3932441
The 3932388 was a 1969 only casting used for 302s and 350s not 327s. It has 4 bolt mains, the only way it came. I suspect what you're reading as an HV suffix is really either HU or HY. HU is 255 horse 4 bbl used only in B bodies. HY is 300 horse 4 bbl used only in B bodies. The difference between them mostly is the cam timing. Given the big chamber 441 head which is year and application appropriate, I'd say you're looking at an upper power level but not high performance 350. The lack of the VIN being stamped on the engine might say this is a dealer installation, perhaps a warranty replacement or the engine has been rebuilt including a block decking that took the serial number off.
Your VIN says it's a 1969 Impala or Caprice, made in L.A.
Bogie
Old 10-12-2010, 04:19 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
This is what mortec shows for the block. 3932388....327.....69....2 /
3932388....350.....69....2 or 4.
Here is what they have on the heads.
3932441....69-70...350..........76cc chambers
Cole
Old 10-12-2010, 04:25 PM
eloc431962's Avatar
Wiki Edits: 37
What did the guy's over at impalaforums have to say about it ? That is you that posted over there right same vin# and info anyway.
Just courious. Nevermind i checked and noboby has replied yet.
Like Bogie said check your HV at the end of your suffix code.
Cole
Old 10-12-2010, 04:49 PM
eloc431962's Avatar
Wiki Edits: 37
And i almost forgot. The T= Tonawanda New York / 09= September 04= 4th day.
So that means it was from Tonawanda New York on September 4th.
The rest you need to re-check and make darn sure what the last two letters are. It's real easy to miss read the codes.JMO
Cole
Old 10-12-2010, 05:00 PM
eloc431962's Avatar
Wiki Edits: 37
Heres how i have the vin# brake down.
1969 Chevrolet Impala Convertible
1 Line Chevrolet
64 Series Impala 8 Cyl.
67 Body Convertible 2-Door
9 Year 1969
C Assembly Southgate, CA
043566 Serial 043566
Cole
Old 10-12-2010, 05:52 PM
I think I got the 327 info from a Camaro site. Here are #pics. If you tell me that isnt an HV I'm going straight to the eye doctor.
I got a PM telling me I may get better info over here than the Impala forum.
ID:	48837   Click image for larger version
ID:	48838   Click image for larger version
Old 10-12-2010, 06:34 PM
eloc431962's Avatar
Wiki Edits: 37
Yep that's a V don't worry bout your eye's
Cole
Old 10-12-2010, 06:38 PM
Thanks for that verification Cole. Now so what does the suffix code and engine block # tell me? I'm still lost.
Old 10-12-2010, 06:45 PM
eloc431962's Avatar
Wiki Edits: 37
Cole
Well here's what the block and heads above tell us.
And the suffix code T0904HV say's it's a 1965 corvette 350 HP 327. T= Tonawanda New York / 09= September 04= 4th day HV=1965 Corvette 350 HP 327.
That's what i get anyway. Sounds to me like you have a good one there.
Cole
Old 10-12-2010, 07:49 PM
So what would be the determining factor in telling what it actually is? I have never had a motor confuse me the way this one has...the only thing I am pretty sure on is that since the partial VIN isnt by the suffix, it is not the original motor.
Old 10-12-2010, 07:55 PM
eloc431962's Avatar
Wiki Edits: 37
That's what i am leaning to also. Maybe someone else will chime in and shead some light on this for you. I was also wondering if maybe the block was a left over like a replacement block that was just sitting there and they put it in your car but i really don't know. If you think about it mortec has the block as a 69 model block and the suffix is from a 65 vette. But i am sure someone on here will know.JMO
It's got to be one of the two IMHO. Wish i could be of more help.
Cole
Old 10-12-2010, 08:01 PM
Thanks for the help though, Cole. Then you have info like Bogie stated that it isnt a 327 yet the suffix code says it is. Thanks again.
Old 10-12-2010, 08:03 PM
eloc431962's Avatar
Wiki Edits: 37
Glad i could help and you keep safe over there ok.
Cole
Old 10-12-2010, 08:14 PM
Last journal entry: hillbilly ratrod
check -id
hello maybe this will help.......google this....chevy s/b id,very helpfull 4 me to id motors,c -ya mowgas
engine vin codes badmystur Engine 2 09-24-2010 09:31 PM
vin and engine id needed Leadfoot Lonny Engine 2 09-11-2010 07:32 PM
Anyone decode a engine VIN no.? rp23g7 Engine 8 06-05-2010 04:06 PM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 12:53 PM
engine vin help 91camarors Hotrodding Basics 2 01-05-2009 01:48 PM
