engine wire harness
hi, i'm about to start working on a viper engine before we start modding the frame of the merc where it is going in to and i have a wire question for you:
as the OEM wiring is dammaged should I look for a new OEM wire set or go for a "viper wire harness for non viper applications" you can find on different sites. I have a PCM and plan to use autometer gauges.
Are some of the stock sensors on the engine/trans obsolete ? will it give PCM errors if i don't use all sensors ?
i want to make it as reliable as possible.
