engine wire harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2012, 04:35 PM
engine wire harness
hi, i'm about to start working on a viper engine before we start modding the frame of the merc where it is going in to and i have a wire question for you:
as the OEM wiring is dammaged should I look for a new OEM wire set or go for a "viper wire harness for non viper applications" you can find on different sites. I have a PCM and plan to use autometer gauges.
Are some of the stock sensors on the engine/trans obsolete ? will it give PCM errors if i don't use all sensors ?
i want to make it as reliable as possible.
Engine wire harness ? Bucketwrench Electrical 4 10-24-2010 04:43 PM
wire harness removal 1badbird89 Electrical 8 12-22-2007 12:57 PM
wire harness wayneo Electrical 1 10-18-2007 06:59 PM
wire harness wayneo Electrical 5 10-15-2007 08:43 AM
Wire harness 1931 steve Electrical 12 12-15-2005 11:06 AM
