engine wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2011, 07:59 PM
engine wiring
i need help with my 1984 Chevy caprice i put a rebuilt 305 in there and just need to do the wring and vacuum wiring
Old 07-18-2011, 07:41 PM
LATECH's Avatar
The emission sticker under the hood should show the hose routing and connections, if not you can get it at alldata DIY or at a gm dealerif you ask them nicely.
The wiring should be plug and play as long as you didnt alter any of the CCC system that was factory installed. If you cut and chopped the wiring, just use the big pink or big red wire for the HEI with vacuum advance that you will be needing next to get the ignition to fire the engine.
Old 07-18-2011, 08:16 PM
Wiki Edits: 27
copy
oops hit the button twice
Old 07-18-2011, 08:17 PM
Wiki Edits: 27
public library
When I was working in Calif the San Jose public library had a very good automotive reference section. NO check outs, but you could make enlarged copies of what ever you needed, wiring, emission- hose routing.. etc.
Old 07-18-2011, 08:55 PM
thanks
okay thanks guys now i going to put the carb on
wiring engine dieselguy66 Electrical 3 06-10-2009 07:33 AM
engine wiring ed hall Introduce Yourself 1 08-22-2004 07:16 AM
engine wiring ed hall Introduce Yourself 1 08-22-2004 07:12 AM
Engine wiring al37ford Electrical 10 08-06-2004 06:34 PM
engine wiring bobby r. smith Engine 4 06-26-2002 07:32 PM
