engine wont idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2011, 05:38 PM
engine wont idle
i just rebuilt my edelbrock carb and now it wont idle under 1000 rpms its on a stock chevy 350 works great when driving just wont idle checked all vacume lines good sims to have alot of fuel dumping in when idling high but cant get it to idle any lower any sugestions
Old 04-06-2011, 08:48 PM
Sounds as if the float adjustment did not go well maybe? I would start with checking float level or look down in the carb to see if there is an abundant amount of fuel coming out of the top end of carb. Did it run better than this before the rebuild?
Old 04-06-2011, 10:10 PM
it had a holly on it origanly did same thing with it actually runs better with edelbrock on it just cant get it to idle right it have to keep it idled high but idles rough get smoother the higher you rev it
Old 04-06-2011, 10:32 PM
techinspector1's Avatar
Wiki Edits: 326
Regulate your fuel pressure to 5 psi at the carb inlet.
Old 04-06-2011, 10:43 PM
DoubleVision's Avatar
This can be caused by Float level too high, fuel pressure too high, needle stuck open in seat, ignition timing set too low, major vacuum leak.
Where did you set the idle mixture screws upon reassembly?
Old 04-06-2011, 10:56 PM
i set the mixture screws all the way in then backed out 2 turns and set floats at the 7/16 gap like manuel said and even tried pluging all vacum portsand still had no change but havent tried regulating fuel presure
Old 04-07-2011, 05:47 PM
There really is a lot of things that can cause this problem like the other post have mentioned. The first thing I would do is take some carb spray and spray into the carb to see if it boggs down or speeds up to determine if you have a lean or rich condition as close to an idle rpm as possible. If it speeds up spray around the top of motor to check for vac leaks.
Old 04-07-2011, 08:59 PM
idle bad
you might have a crack in your intake or a bad vacume leak that is letting yousuck in a lot of air .
Old 04-07-2011, 09:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Be sure the choke is fully open once the engine is warmed up. Also set the initial timing to about 10-14 w/o the vacuum advance added in.
Start by adjusting the idle mixture screws using a vacuum gauge or tach to get the fastest idle or most vacuum at idle. This will need to be done w/the engine at a normal idle speed though.
To get a normal idle speed, look at where the curb idle screw contacts the throttle arm to be sure there actually IS contact there- if not, the choke fast idle screw may be contacting the fast idle cam or there may be bent, out of adjustment or incorrectly assembled choke components.
If none of this helps the idle ( which wouldn't be too surprising considering it did this w/two different carbs), you'll need to look elsewhere for vacuum leaks, etc. as mentioned above.
engine wont idle, or stay running lowandloud91 Engine 16 08-10-2009 01:27 PM
3800 wont idle? runn141 Engine 6 11-02-2008 05:53 PM
Q-Jet wont idle?!? 87442lover Engine 5 01-25-2004 12:01 PM
Wont idle below 1000RPM Trav Engine 6 12-10-2003 06:43 PM
92 ford 302 EFI wont idle cgreene General Rodding Tech 5 11-05-2003 09:50 PM
