Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine wont idle, or stay running
Old 08-06-2009, 03:58 PM
lowandloud91 lowandloud91 is offline
well to start off my engine will start and then usualy idle high for mabey 10-20 sec and then shut off. Ive tried messing with the timimg and carb a bunchhh and nothing seems to help...any ideas??
also this is a new motor
heres the set up:
355 w/flat tops, 64cc/197 al. heads w/ 1.5 rollers, air gap intake, 750 speed demon carb, and comp cams 282 hyd. roller .510/.520 lift, 282/288 duration230/236 duration @ 50
thanks for any help!
