engine wont idle, or stay running - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-10-2009, 06:13 AM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by lowandloud91
mk ill do that and see what happens. i know this shouldnt matter at all, i dont think anyways, but my belt is not on. it should run without that right? if the carb adjusting does not fix the problem what should i do next?
thanks for all the input!
If you are talking about the alternator belt, yes it can make a difference. Low voltage will cause the ignition to be weak and your electric pump to pump less.
Chet
  #17 (permalink)
Old 08-10-2009, 12:27 PM
If it has the juice to start the engine shouldnt the battery have enough power to run the pump and ignition system? It does sound fuel related. Did you check the fuel filter? Needle stuck in the seat? Floats low?
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
timing question Radchop Engine 7 11-19-2008 09:16 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
Cam lope question joeford Engine 4 08-10-2006 08:14 AM
Ported Vacuum 72Orange Engine 18 08-07-2006 08:56 PM
