engine won't run - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2010, 10:39 AM
engine won't run
hello everone,
have 1995 s10 blazer 4x4 with vortec w motor. it became hard to start
and then it would not start at all.i pulled the plugs, they all look good
eccept #3 .when i pulled the plug, fuel ran out of the hole. a lot. after
i pulled the plugs i could turn the motor by hand i replaced the timeing
chain put back togather same happened.it will make about a halfturn
then lockup with fuel in the same cylinder.any help will be much
appreceated.
Old 04-06-2010, 10:45 AM
bondo's Avatar
Originally Posted by Lew51
hello everone,
appreceated.
Ayuh,... Sounds like it's running atad Rich...
Probably otta be looking for where the gas is Leaking...
Buick 430 Engine 70LEBUICK Engine 5 02-24-2010 09:57 PM
Painting Engine. Will it run Hotter? scrimshaw General Rodding Tech 8 07-03-2009 08:50 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
engine not run in years fezz-man Engine 16 01-10-2005 09:06 PM
engine firing but wont run lovemy68bird Engine 10 02-12-2004 07:29 PM
