engine won't run :>( - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2011, 02:33 PM
Prof. T. Soggmeyer's Avatar
Plan B
Hello, I have a 283 out of a 66 chevelle. It was pulled from a 52 p/u., it has 10,000 miles on it. I put it in my 49 chevy p/u along with a painless wiring kit. The engine starts to fire but won't quite run. I have HEI dist. in it and an electric fuel pump. The painless wire to the dist stays hot when the key is in the "on" position as well....any clues?
Thanx in advance
Brad
Old 11-06-2011, 02:39 PM
0pyders's Avatar
You mean like it cranks over and starts spinning faster like it's about to run but it just won't? If so I had the same problem. My distributor was too far retarded so I moved it clockwise just a little bit.
Old 11-06-2011, 04:06 PM
LATECH's Avatar
Opyders is on the right track, but to advance the timing you need to turn the distributor a little counterclockwise to advance it.
But I agree, it is probably timing that is the issue.
Hi Opyders.
Old 11-06-2011, 06:12 PM
Plan B
283 won't start
Hi Opyders.
Is TDC a good place to start?
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 06:48 PM
Engine Help. Engine Turns over Hard, like siezed yet runs awsome. Merle9069 Engine 3 10-05-2008 06:38 PM
I need engine mount bracket ideas 1930 chevy with 302 boss engine. Riley Engine 3 07-25-2008 07:29 AM
Ford 302 engine to engine stand bolt size? Lee in Texas Engine 4 03-24-2008 10:30 AM
say you have a THOUSAND horsepower engine..... (technical engine question inside) lowROLLERchevy Engine 14 02-24-2007 08:26 AM
