engine won't start - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2008, 06:50 PM
untchable502's Avatar
engine won't start
ok i have a chevy 350 freshly rebuilt, hei distirbutor w/ vac advance, .o35 gap in plugs, edelbrock 1405, oem fuel pump....
well anyways went to start it up for the first time today, and at first it cranked alittle bit, then it caught alittle then it kinda poofed through the car followed by a fireball, did that scenarios a couple of times, while adjusting the distributor different ways, finally i thought maybe i'm a 180 off, pulled distributor rotated and reset it, then it just backfired through the carb.... any ideas?????
Old 04-13-2008, 07:07 PM
Jmark's Avatar
Start from the beginning.
Pull #1 plug, put your finger in the hole and have someone bump the starter. When your finger blows out, STOP and manually rotate the crank until the timing mark lines up close to 12 degrees.
Remove the dist cap and see where the rotor is pointing. If it's not at #1 wire, reposition the dist. If it's ok, ck the valve adjustment. Too tight and it will backfire and not run.
Old 04-13-2008, 08:12 PM
check to make sure your wires are in the right order 1 8 4 3 6 5 7 2 and make sure they are going clockwise not counterclock wise.i did that with mine had the right firing order but in reverse, dam thing was spitting fire throught the carb then the exchaust, open headers set the dry grass on fire almost the the dam truck
Old 04-13-2008, 08:48 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Originally Posted by wayneo
check to make sure your wires are in the right order 1 8 4 3 6 5 7 2 and make sure they are going clockwise not counterclock wise.i did that with mine had the right firing order buy in reverse dam thing was spitting throught the carb then the exchaust
Ha! I did that once myself, those race header's on that BBC 481CID 981HP drag boat engine were throwing flames out right by my shoulders.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
Engine Start Up sjohn Engine 16 05-18-2006 11:18 PM
Engine won't start longt Engine 2 10-24-2005 11:14 AM
Help! engine won't start Jeep'n Engine 9 11-13-2003 09:39 AM
